Ga door naar hoofdinhoud
Lenovo Essential G560 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo Essential G560 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
    Vraag FixBot
    Voeg opmerking toe
  2. Lenovo Essential G560 Keyboard Replacement: stap 2, afbeelding 1 van 2 Lenovo Essential G560 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
    Vraag FixBot
    Voeg opmerking toe
  3. Lenovo Essential G560 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
    Vraag FixBot
    Voeg opmerking toe
  4. Lenovo Essential G560 Keyboard Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
    Vraag FixBot
    Voeg opmerking toe
  5. Lenovo Essential G560 Keyboard Replacement: stap 5, afbeelding 1 van 2 Lenovo Essential G560 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    Vraag FixBot
    Voeg opmerking toe
  6. Lenovo Essential G560 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Lenovo Essential G560 Keyboard Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
    • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
    Vraag FixBot
    Voeg opmerking toe
  8. Lenovo Essential G560 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Flip the computer over.
    • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Lenovo Essential G560 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
    • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  10. Lenovo Essential G560 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the keyboard up from the bezel.
    • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull the keyboard cable from its socket.
    • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Dennis Wong
618 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-40, Regan Winter 2013 Lid van Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Leden
13 handleidingen geschreven
2Gids Commentaar
Thank you frndzz
Anand krishnan - Antwoord Deel
Thank you frndz
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 66
Altijd: 19,498
