Ga door naar hoofdinhoud
Lenovo Essential B570 RAM Replacement
Wat je nodig hebt
    1. Lenovo Essential B570 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
      • Turn over laptop.
      • Switch open the left battery lock.
      • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo Essential B570 RAM Replacement: stap 2, afbeelding 1 van 1
      • Hold the right battery lock open with one hand while removing the battery itself with the other.
      Vraag FixBot
      Voeg opmerking toe
    1. Lenovo Essential B570 RAM Replacement, Back Panel: stap 3, afbeelding 1 van 1
      • Loosen the five Philips screws that secure the panel.
      • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo Essential B570 RAM Replacement: stap 4, afbeelding 1 van 3 Lenovo Essential B570 RAM Replacement: stap 4, afbeelding 2 van 3 Lenovo Essential B570 RAM Replacement: stap 4, afbeelding 3 van 3
      • Prop open the cover with a plastic opening tool.
      • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
      Vraag FixBot
      Voeg opmerking toe
    1. Lenovo Essential B570 RAM Replacement, RAM: stap 5, afbeelding 1 van 2 Lenovo Essential B570 RAM Replacement, RAM: stap 5, afbeelding 2 van 2
      • Release your RAM by pulling its locks away from one another.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo Essential B570 RAM Replacement: stap 6, afbeelding 1 van 2 Lenovo Essential B570 RAM Replacement: stap 6, afbeelding 2 van 2
      • Remove RAM by carefully pulling it away from its socket.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Samuel Filliettaz
900 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-5, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 27
Altijd: 1,305
