Ga door naar hoofdinhoud
Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement
Wat je nodig hebt
  1. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 5, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 5, afbeelding 2 van 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: stap 7, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: stap 7, afbeelding 2 van 2
    • Remove the single 2 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 8, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 8, afbeelding 2 van 2
    • Detach the Wi-Fi card from the motherboard using an iFixit opening tool.
  9. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 9, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, disconnect the two wires from the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 45
Altijd: 793
