Ga door naar hoofdinhoud
Lenovo 500e Chromebook 2nd Gen Speakers Replacement
Wat je nodig hebt
  1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 2, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 2, afbeelding 2 van 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 3, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 3, afbeelding 2 van 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 5, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 5, afbeelding 2 van 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Speakers: stap 7, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Speakers: stap 7, afbeelding 2 van 2
    • Remove the two 4 mm screws (one on each speaker) using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 8, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 8, afbeelding 2 van 2
    • Use the iFixit opening tool to detach the right speaker cable from the motherboard.
  9. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: stap 9, afbeelding 1 van 1
    • Remove both speakers by gently pulling them out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 166
