Ga door naar hoofdinhoud
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
Wat je nodig hebt
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 2, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 3, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 5, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 8, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 9, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 10, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 12, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 13, afbeelding 1 van 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 13, afbeelding 2 van 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 14, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 15, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 16, afbeelding 1 van 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 16, afbeelding 2 van 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 17, afbeelding 1 van 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 17, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Gently remove the motherboard from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 47
Altijd: 742
