Ga door naar hoofdinhoud
Lego Dimensions Starter Pack LED Chip Replacement
Wat je nodig hebt
  1. Lego Dimensions Starter Pack LED Chip Replacement, Top Cover Parts: stap 1, afbeelding 1 van 2 Lego Dimensions Starter Pack LED Chip Replacement, Top Cover Parts: stap 1, afbeelding 2 van 2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack LED Chip Replacement: stap 2, afbeelding 1 van 1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack LED Chip Replacement: stap 3, afbeelding 1 van 1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack LED Chip Replacement: stap 4, afbeelding 1 van 1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack LED Chip Replacement: stap 5, afbeelding 1 van 1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack LED Chip Replacement, USB Cable: stap 6, afbeelding 1 van 1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
  7. Lego Dimensions Starter Pack LED Chip Replacement, LED Chip: stap 7, afbeelding 1 van 1
    • Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
    • Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
  8. Lego Dimensions Starter Pack LED Chip Replacement: stap 8, afbeelding 1 van 1
    • Pull the ribbon away from the black connector of the LED chips.
    • Disconnect the ribbon from the other LED chip as well, if replacing both LED chips or the motherboard.
  9. Lego Dimensions Starter Pack LED Chip Replacement: stap 9, afbeelding 1 van 1
    • Lift up both LED chips. As you are lifting, pull towards the motherboard to release it from the toy pad cover.
  10. Lego Dimensions Starter Pack LED Chip Replacement: stap 10, afbeelding 1 van 1
    • Lift up the motherboard, and remove the motherboard and LED chips from the toy pad.
  11. Lego Dimensions Starter Pack LED Chip Replacement: stap 11, afbeelding 1 van 1
    • Flip the motherboard and LED chips over.
    • Desolder the LED chip from the motherboard.
    • Desolder both LED chips, if replacing both LED chips or the motherboard
    • Separate the LED chip(s) from the motherboard.
    • Refer to this guide for soldering and desoldering tips.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alyssa Lach
509 Reputatie
4 handleidingen geschreven
IUPUI, Team S5-G2, Baechle Fall 2017 Lid van IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,236
