Ga door naar hoofdinhoud
Lefant M210 Wheel Assembly Replacement
Wat je nodig hebt
    1. Lefant M210 Wheel Assembly Replacement, Brush: stap 1, afbeelding 1 van 2 Lefant M210 Wheel Assembly Replacement, Brush: stap 1, afbeelding 2 van 2
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      Vraag FixBot
      Voeg opmerking toe
    2. Lefant M210 Wheel Assembly Replacement: stap 2, afbeelding 1 van 3 Lefant M210 Wheel Assembly Replacement: stap 2, afbeelding 2 van 3 Lefant M210 Wheel Assembly Replacement: stap 2, afbeelding 3 van 3
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      Vraag FixBot
      Voeg opmerking toe
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      Vraag FixBot
      Voeg opmerking toe
    1. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: stap 4, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove four screws near each wheel.
      Vraag FixBot
      Voeg opmerking toe
    2. Lefant M210 Wheel Assembly Replacement: stap 5, afbeelding 1 van 2 Lefant M210 Wheel Assembly Replacement: stap 5, afbeelding 2 van 2
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      Vraag FixBot
      Voeg opmerking toe
    3. Lefant M210 Wheel Assembly Replacement: stap 6, afbeelding 1 van 3 Lefant M210 Wheel Assembly Replacement: stap 6, afbeelding 2 van 3 Lefant M210 Wheel Assembly Replacement: stap 6, afbeelding 3 van 3
      • Hold the wheel up and detach the connector to release it from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Adrian pg
147 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Lid van CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Leden
13 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 161
Altijd: 2,028
