Ga door naar hoofdinhoud
Led Lenser P2 BM Button Disassembly
Wat je nodig hebt
    1. Led Lenser  P2 BM  Button Disassembly, Unscrew rear cap from the main housing: stap 1, afbeelding 1 van 1
      • This is exactly how you would do it if you were changing the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Led Lenser  P2 BM  Button Disassembly, Remove O-ring: stap 2, afbeelding 1 van 1
      • Remove the small O-Ring, I used a plastic toothpick.
      Vraag FixBot
      Voeg opmerking toe
    3. Led Lenser  P2 BM  Button Disassembly, Screw apart cap: stap 3, afbeelding 1 van 2 Led Lenser  P2 BM  Button Disassembly, Screw apart cap: stap 3, afbeelding 2 van 2
      • Now we will unscrew the aluminum cap from the plastic lower part. I used a pair of pliers to carefully hold the plastic part while unscrewing the aluminum part with my finger. Left-hand thread.
      Vraag FixBot
      Voeg opmerking toe
    4. Led Lenser  P2 BM  Button Disassembly, Split housing: stap 4, afbeelding 1 van 1
      • The plastic housing holds the actual button assembly and is made from two halves, These can carefully be pried apart wit a knife.
      Vraag FixBot
      Voeg opmerking toe
    5. Led Lenser  P2 BM  Button Disassembly, Open button assembly: stap 5, afbeelding 1 van 2 Led Lenser  P2 BM  Button Disassembly, Open button assembly: stap 5, afbeelding 2 van 2
      • Button assembly mark in red circle. This is held together by 4 plastic "rivets" on the connector side, marked in green. Cafully cut these flush like in the picture.
      Vraag FixBot
      Voeg opmerking toe
    6. Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: stap 6, afbeelding 1 van 2 Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: stap 6, afbeelding 2 van 2
      • You can then pry of the "lid" like in the third picture.
      • Carefully remove the inner springs and plungers. In the picture one small plunger is still in the top of the button.
      • In my case the problem was a tiny plastic "!shaving" inside the button blocking it from making a connection, Market with yellow arrow.
      Vraag FixBot
      Voeg opmerking toe
    7. Led Lenser  P2 BM  Button Disassembly, Reassemble: stap 7, afbeelding 1 van 1
      • Is reversed of disassembly but you don't need to glue the button together (the small plastic "rivets" are now broken) because the two part plastic housing will keep it together when assembled.
      • I have used it like this for years until the same problem happen again, so added some new images while fixing it again.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hans
430 Reputatie
2 handleidingen geschreven
3Gids Commentaar
Dear Hans.
I have used the same P3 LED for many years in bad switch condition.
Today I cleared this problem with your solution.
Very thank you & I'm appreciate to you.
DS2DDE
from Seoul, Korea.
김도욱 - Antwoord Deel
can you show how to take the front part apart?
Eric Secreve - Antwoord Deel
@ericsecreve Sadly I lost the light on an exercise, it's somewhere out in the woods now, all alone, cold and wet.
Hans - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 120
Altijd: 4,826
