Ga door naar hoofdinhoud
Leapfrog My Own Leaptop Battery Replacement Guide
Wat je nodig hebt
    1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: stap 1, afbeelding 1 van 1
      • Flip over device so that back portion of the device is facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. Leapfrog My Own Leaptop Battery Replacement Guide: stap 2, afbeelding 1 van 1
      • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
      • Please note that the screw cannot be removed as it is attached to the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Leapfrog My Own Leaptop Battery Replacement Guide: stap 3, afbeelding 1 van 2 Leapfrog My Own Leaptop Battery Replacement Guide: stap 3, afbeelding 2 van 2
      • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
      • Remove the three AA batteries.
      • Note the direction of the batteries for when reassembling.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Jonathan Fitzer
629 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-6, Lacy Spring 2016 Lid van USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Leden
6 handleidingen geschreven
1Gids Commentaar
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 74
Altijd: 4,558
