Inleiding
Is your device not making sound? Amplify your happiness by replacing the speaker.
This guide will require soldering equipment and skill.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Before disassembling your LeapPad, ensure your device is shut off.
Push outward on the plastic side panels to remove and reveal battery.
The panels should detach fully from the main device.
Remove the following screws securing the back cover to the main device:
Two 10.0 mm Phillips screws
Four 4.0 mm Phillips screws
Three 3.0 mm Phillips screws
Remove the following screws securing the front cover to the main device:
Three 6.0 mm Phillips screws
Three 7.0 mm Phillips screws
Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
Finally, locate and desolder the remaining connections from speaker wires on the circuit.
Once finished desoldering, flip to the other side of the circuit board to remove the wires.
Één andere persoon heeft deze handleiding voltooid.
