Ga door naar hoofdinhoud
LeapFrog LeapPad2 Explorer Back Camera Replacement
Wat je nodig hebt
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: stap 1, afbeelding 2 van 2
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      Vraag FixBot
      Voeg opmerking toe
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 2, afbeelding 1 van 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 2, afbeelding 2 van 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 2, afbeelding 3 van 3
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: stap 3, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: stap 3, afbeelding 2 van 2
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      Vraag FixBot
      Voeg opmerking toe
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 4, afbeelding 1 van 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 4, afbeelding 2 van 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 4, afbeelding 3 van 3
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      Vraag FixBot
      Voeg opmerking toe
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: stap 5, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: stap 5, afbeelding 2 van 2
      • Locate the back camera below the game cartridge.
      Vraag FixBot
      Voeg opmerking toe
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 6, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 6, afbeelding 2 van 2
      • To safely remove the ribbon cable, first you must pull up the retaining flap.
      • Removing or reinserting the cable by brute force can damage it.
      Vraag FixBot
      Voeg opmerking toe
    3. LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 7, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 7, afbeelding 2 van 2
      • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. LeapFrog LeapPad2 Explorer Back Camera Replacement: stap 8, afbeelding 1 van 1
      • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nupur Garg
867 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2014 Lid van Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 1,533
