Inleiding
First, check to see if the volume is turned up to a reasonable level by using both the volume rocker on the side of the device and the digital volume bar in the settings menu. If the troubleshooting has not solved the issue, the volume rocker will need to be replaced in a few simple steps. Minimal tools will be needed for this guide.
Wat je nodig hebt
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Remove the four 2.5 mm Phillips #00 head screws from the circuit board near the top of the tablet.
Één andere persoon heeft deze handleiding voltooid.
