Ga door naar hoofdinhoud
Le Pan S Battery Replacement
Wat je nodig hebt
    1. Le Pan S Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      Vraag FixBot
      Voeg opmerking toe
    2. Le Pan S Battery Replacement: stap 2, afbeelding 1 van 2 Le Pan S Battery Replacement: stap 2, afbeelding 2 van 2
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      Vraag FixBot
      Voeg opmerking toe
    3. Le Pan S Battery Replacement: stap 3, afbeelding 1 van 1
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      Vraag FixBot
      Voeg opmerking toe
    4. Le Pan S Battery Replacement: stap 4, afbeelding 1 van 2 Le Pan S Battery Replacement: stap 4, afbeelding 2 van 2
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Maria Dole
395 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-1, Harley Fall 2015 Lid van IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Leden
10 handleidingen geschreven
5Gids Commentaar
where can I purchase a battery for a tc978
Timothy - Antwoord Deel
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel - Antwoord Deel
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - Antwoord Deel
Where can I purchase the battery needed?????????????????
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 41
Altijd: 5,916
