Ga door naar hoofdinhoud
Lasko 2002W Motor Replacement
Wat je nodig hebt
  1. Lasko 2002W Motor Replacement, Remove cover: stap 1, afbeelding 1 van 1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: stap 2, afbeelding 1 van 1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: stap 3, afbeelding 1 van 1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: stap 4, afbeelding 1 van 1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: stap 5, afbeelding 1 van 1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
Conclusie
9 andere personen hebben deze handleiding voltooid.
elsa
382 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-39, Donnelly Fall 2014 Lid van USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 Lid
1 handleiding geschreven
Één opmerking
What is the part number for replacement motor? Where do you get it?
Paul Dias - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 3,750
