Inleiding
If you need to repair or replace the microphone, this is the guide you need!
Wat je nodig hebt
Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
Één andere persoon heeft deze handleiding voltooid.
