Ga door naar hoofdinhoud
LG X Power Charging Port Replacement
Wat je nodig hebt
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: stap 1, afbeelding 1 van 2 LG X Power Charging Port Replacement, LG X Power Disassembly: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: stap 2, afbeelding 1 van 2 LG X Power Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: stap 3, afbeelding 1 van 2 LG X Power Charging Port Replacement: stap 3, afbeelding 2 van 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: stap 4, afbeelding 1 van 3 LG X Power Charging Port Replacement, Charging Port: stap 4, afbeelding 2 van 3 LG X Power Charging Port Replacement, Charging Port: stap 4, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Chad Sears
1.170 Reputatie
5 handleidingen geschreven
USF Tampa, Team S3-G6, Nance Spring 2018 Lid van USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Leden
12 handleidingen geschreven
Één opmerking
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 5,942
