Inleiding
Use this guide to replace the pressure sensor in your LG WM3050CW Washing Machine.
The pressure sensor detects how much water is in the tub. The sensor LG uses in these washers have no moving parts, so it's unlikely to break. If the sensor malfunctions, the tub may under-fill or overfill.
Wat je nodig hebt
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
Disconnect the spade connector from the pressure sensor.
Use a Phillips driver to remove the 16.5 mm-long screw securing the pressure sensor.
Rotate the pressure sensor toward the left edge of the washing machine to unclip it from the main board cover.
Repair didn’t go as planned? Ask our Answers community for help.
