Inleiding
Use this guide to replace the LCD screen.
Wat je nodig hebt
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
Remove the 3.5mm screw holding the antenna guide in place with a Philips #00 screwdriver.
Slide the antenna out to the edge, and remove the plastic tubing by gently pulling it out from the opposite end of the antenna.
After separating the front casing from the mid frame, begin prying the screen out.
Use a plastic opening tool to completely remove the screen.
3 andere personen hebben deze handleiding voltooid.
