Ga door naar hoofdinhoud
LG VX8700 Camera Replacement
Wat je nodig hebt
  1. LG VX8700 Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LG VX8700 Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. LG VX8700 Camera Replacement: stap 2, afbeelding 1 van 2 LG VX8700 Camera Replacement: stap 2, afbeelding 2 van 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. LG VX8700 Camera Replacement, Front Bezel: stap 3, afbeelding 1 van 1
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
    Vraag FixBot
    Voeg opmerking toe
  4. LG VX8700 Camera Replacement: stap 4, afbeelding 1 van 2 LG VX8700 Camera Replacement: stap 4, afbeelding 2 van 2
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
    Vraag FixBot
    Voeg opmerking toe
  5. LG VX8700 Camera Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. LG VX8700 Camera Replacement: stap 6, afbeelding 1 van 2 LG VX8700 Camera Replacement: stap 6, afbeelding 2 van 2
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
    Vraag FixBot
    Voeg opmerking toe
  7. LG VX8700 Camera Replacement, Camera: stap 7, afbeelding 1 van 1
    • Now we have the LCD outer case off. The LCD display can be seen on the left, the camera on the right.
    • Place the phone assembly down, it is not needed anymore.
    Vraag FixBot
    Voeg opmerking toe
  8. LG VX8700 Camera Replacement: stap 8, afbeelding 1 van 1
    • To remove the camera the ribbon connector should be removed.
    • This ribbon connector is glued to the case, using the plastic opening tool pry the connector off.
    Vraag FixBot
    Voeg opmerking toe
  9. LG VX8700 Camera Replacement: stap 9, afbeelding 1 van 1
    • The camera should come loose after the connector is pried off.
    • Take the new camera and apply a small square of double sided tape to the new ribbon connector.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Andrew
7 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-16, Maness Winter 2012 Lid van Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 981
