Inleiding
If no sound comes from headphones that are plugged into the audio port, you may need to install a new one. Follow this guide to diagnose and resolve the issue.
Wat je nodig hebt
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
