Ga door naar hoofdinhoud
LG VX5200 LCD Screen Replacement
Wat je nodig hebt
  1. LG VX5200 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 LG VX5200 LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the phone on its back.
  2. LG VX5200 LCD Screen Replacement: stap 2, afbeelding 1 van 2 LG VX5200 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 LCD Screen Replacement: stap 3, afbeelding 1 van 2 LG VX5200 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 LCD Screen Replacement, Face Plate: stap 4, afbeelding 1 van 3 LG VX5200 LCD Screen Replacement, Face Plate: stap 4, afbeelding 2 van 3 LG VX5200 LCD Screen Replacement, Face Plate: stap 4, afbeelding 3 van 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 LCD Screen Replacement: stap 5, afbeelding 1 van 3 LG VX5200 LCD Screen Replacement: stap 5, afbeelding 2 van 3 LG VX5200 LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 LCD Screen Replacement: stap 6, afbeelding 1 van 3 LG VX5200 LCD Screen Replacement: stap 6, afbeelding 2 van 3 LG VX5200 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 LCD Screen Replacement, LCD Screen: stap 7, afbeelding 1 van 2 LG VX5200 LCD Screen Replacement, LCD Screen: stap 7, afbeelding 2 van 2
    • Try not to move the thin component wires as they will bend and break very easily.
  8. LG VX5200 LCD Screen Replacement: stap 8, afbeelding 1 van 3 LG VX5200 LCD Screen Replacement: stap 8, afbeelding 2 van 3 LG VX5200 LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
  9. LG VX5200 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Gently lift out the speaker with your fingertip.
  10. LG VX5200 LCD Screen Replacement: stap 10, afbeelding 1 van 3 LG VX5200 LCD Screen Replacement: stap 10, afbeelding 2 van 3 LG VX5200 LCD Screen Replacement: stap 10, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
  11. LG VX5200 LCD Screen Replacement: stap 11, afbeelding 1 van 2 LG VX5200 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Place phone body and LCD screen on a clean, lint-free surface.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Douglas Blaalid
282 Reputatie
8 handleidingen geschreven
Cal Poly, Team 4-13, Forte Winter 2010 Lid van Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,914
