Ga door naar hoofdinhoud
LG V50 ThinQ Speaker & Charging Port Replacement
Wat je nodig hebt
  1. LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: stap 1, afbeelding 1 van 3 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: stap 1, afbeelding 2 van 3 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: stap 1, afbeelding 3 van 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Speaker & Charging Port Replacement: stap 2, afbeelding 1 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 2, afbeelding 2 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 2, afbeelding 3 van 3
    • With the back side open, remove all 12 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Speaker & Charging Port Replacement: stap 3, afbeelding 1 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 3, afbeelding 2 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Remove the two brackets that are covering internal components.
  4. LG V50 ThinQ Speaker & Charging Port Replacement: stap 4, afbeelding 1 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 4, afbeelding 2 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Disconnect the orange cable by pulling the connector up with your fingers.
    • Pull up with tweezers on the end of the white wire to disconnect it from the two circuit boards.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Speaker & Charging Port Replacement: stap 5, afbeelding 1 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 5, afbeelding 2 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 5, afbeelding 3 van 3
    • Take out the SIM card by using the SIM head and pushing into the SIM ejector slot.
    • Disconnect the orange panel nearby the SIM slot from the circuit board.
    • Pull up from below the circuit board on the top, next to the CMOS battery to remove the upper circuiting from the phone.
  6. LG V50 ThinQ Speaker & Charging Port Replacement: stap 6, afbeelding 1 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 6, afbeelding 2 van 3 LG V50 ThinQ Speaker & Charging Port Replacement: stap 6, afbeelding 3 van 3
    • Pull up from the right of the metallic cover piece inside of the bottom right of the phone.
    • Remove the metallic piece's base from the board.
    • Make the cubic piece moveable by wiggling under it with an opening pick or spudger.
  7. LG V50 ThinQ Speaker & Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Remove bottom circuiting, the speaker system is a part of the bottom circuit board.
Conclusie
William Martin
231 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 34
Altijd: 163
