Ga door naar hoofdinhoud
LG V50 ThinQ Screen Replacement
Wat je nodig hebt
  1. LG V50 ThinQ Screen Replacement, Screen: stap 1, afbeelding 1 van 3 LG V50 ThinQ Screen Replacement, Screen: stap 1, afbeelding 2 van 3 LG V50 ThinQ Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Flip the phone over, making sure that the back of the phone is facing up.
    • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
  2. LG V50 ThinQ Screen Replacement: stap 2, afbeelding 1 van 2 LG V50 ThinQ Screen Replacement: stap 2, afbeelding 2 van 2
    • With the device facing down, remove all 12 1mm Phillips #000 screws.
    • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
  3. LG V50 ThinQ Screen Replacement: stap 3, afbeelding 1 van 3 LG V50 ThinQ Screen Replacement: stap 3, afbeelding 2 van 3 LG V50 ThinQ Screen Replacement: stap 3, afbeelding 3 van 3
    • Remove the two brackets covering the internal components.
  4. LG V50 ThinQ Screen Replacement: stap 4, afbeelding 1 van 2 LG V50 ThinQ Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
  5. LG V50 ThinQ Screen Replacement: stap 5, afbeelding 1 van 1
    • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
    • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
    • Carefully put the replacement screen into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Carlos Rivera
121 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 42
Altijd: 245
