Ga door naar hoofdinhoud
LG UD501KOJ5 Dehumidifier Sensor Replacement
Wat je nodig hebt
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: stap 1, afbeelding 1 van 2 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: stap 1, afbeelding 2 van 2
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 2, afbeelding 1 van 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 2, afbeelding 2 van 2
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 3, afbeelding 1 van 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 3, afbeelding 2 van 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 3, afbeelding 3 van 3
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 4, afbeelding 1 van 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 4, afbeelding 2 van 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 4, afbeelding 3 van 3
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 5, afbeelding 1 van 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 5, afbeelding 2 van 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 6, afbeelding 1 van 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: stap 6, afbeelding 2 van 2
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
Conclusie
Gabrielle Campbell
133 Reputatie
1 Handleiding geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 55
Altijd: 1,900
