Ga door naar hoofdinhoud
LG Tribute lower media Speaker Replacement
Wat je nodig hebt
  1. LG Tribute lower media Speaker  Replacement, Battery: stap 1, afbeelding 1 van 2 LG Tribute lower media Speaker  Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute lower media Speaker  Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute lower media Speaker  Replacement, Mid-panel: stap 3, afbeelding 1 van 2 LG Tribute lower media Speaker  Replacement, Mid-panel: stap 3, afbeelding 2 van 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute lower media Speaker  Replacement: stap 4, afbeelding 1 van 2 LG Tribute lower media Speaker  Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute lower media Speaker  Replacement, Main media Speaker: stap 5, afbeelding 1 van 2 LG Tribute lower media Speaker  Replacement, Main media Speaker: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool or your finger to carefully disconnect the speaker.
Conclusie
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
That's cool how did you get this stuff planned it is awsome.
Taziah brown - Antwoord
This is a brand new phone. Now I have to repair it? Something VERY WRONG with this picture! Is that the best sprint can do?
Ron Lieser - Antwoord
Brand new out of the box phone and I have to repair the speaker. I don't think so!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 947
