Ga door naar hoofdinhoud
LG Tribute Touchscreen Replacement
Wat je nodig hebt
  1. LG Tribute Touchscreen Replacement, Battery: stap 1, afbeelding 1 van 2 LG Tribute Touchscreen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to pry off the back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Tribute Touchscreen Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Tribute Touchscreen Replacement, Mid-panel: stap 3, afbeelding 1 van 2 LG Tribute Touchscreen Replacement, Mid-panel: stap 3, afbeelding 2 van 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    Vraag FixBot
    Voeg opmerking toe
  4. LG Tribute Touchscreen Replacement: stap 4, afbeelding 1 van 2 LG Tribute Touchscreen Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Tribute Touchscreen Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
    Vraag FixBot
    Voeg opmerking toe
  6. LG Tribute Touchscreen Replacement, Touchscreen: stap 6, afbeelding 1 van 3 LG Tribute Touchscreen Replacement, Touchscreen: stap 6, afbeelding 2 van 3 LG Tribute Touchscreen Replacement, Touchscreen: stap 6, afbeelding 3 van 3
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
thank you for all ypu work at web site
salah dholman - Antwoord Deel
Can you peel away lens without taking apart ?
mikeknapik1 - Antwoord Deel
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Antwoord Deel
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 50
Altijd: 16,570
