Ga door naar hoofdinhoud
LG Tribute Rear-Facing Camera Replacement
Wat je nodig hebt
  1. LG Tribute Rear-Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LG Tribute Rear-Facing Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to pry off the back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Tribute Rear-Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Tribute Rear-Facing Camera Replacement, Mid-panel: stap 3, afbeelding 1 van 2 LG Tribute Rear-Facing Camera Replacement, Mid-panel: stap 3, afbeelding 2 van 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    Vraag FixBot
    Voeg opmerking toe
  4. LG Tribute Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 2 LG Tribute Rear-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: stap 5, afbeelding 1 van 2 LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: stap 5, afbeelding 2 van 2
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 908
