Ga door naar hoofdinhoud
LG Thrill 4G SIM/Micro SD Card Replacement
Wat je nodig hebt
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: stap 1, afbeelding 1 van 2 LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: stap 1, afbeelding 2 van 2
      • Pry open the back cover by using a fingernail or a plastic opening tool.
      • There is a small notch at the bottom of the cover for easy removal.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: stap 2, afbeelding 1 van 2 LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: stap 2, afbeelding 2 van 2
      • Remove the battery from the phone.
      • There is a small ledge located at the bottom of the battery for easy removal.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Screw Removal: stap 3, afbeelding 1 van 1
      • Remove the three Philips #00 screws from the bottom of the phone.
      • Two 5.5 mm screws
      • One 4 mm screw
      Vraag FixBot
      Voeg opmerking toe
    2. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: stap 4, afbeelding 1 van 2 LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: stap 4, afbeelding 2 van 2
      • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Buttons: stap 5, afbeelding 1 van 1
      • Remove the three buttons from the side and the top of the phone.
      • Power button
      • Volume button
      • 3D camera button
      Vraag FixBot
      Voeg opmerking toe
    2. LG Thrill 4G SIM/Micro SD Card Replacement: stap 6, afbeelding 1 van 3 LG Thrill 4G SIM/Micro SD Card Replacement: stap 6, afbeelding 2 van 3 LG Thrill 4G SIM/Micro SD Card Replacement: stap 6, afbeelding 3 van 3
      • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
      • This loosens both the HDMI and USB covers for easy removal.
      • USB Cover
      • HDMI Cover
      Vraag FixBot
      Voeg opmerking toe
    3. LG Thrill 4G SIM/Micro SD Card Replacement: stap 7, afbeelding 1 van 1
      • Remove the six Phillips #00 screws within the mid-cover bezel.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: stap 8, afbeelding 1 van 3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: stap 8, afbeelding 2 van 3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: stap 8, afbeelding 3 van 3
      • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: stap 9, afbeelding 1 van 3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: stap 9, afbeelding 2 van 3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: stap 9, afbeelding 3 van 3
      • Carefully pry the board up to detach it from its place in the phone.
      • Make sure to pry off the small tab connected to the camera unit as well.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Khbero Baker
128 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-6, Blackwell Winter 2015 Lid van USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 929
