Ga door naar hoofdinhoud
LG Realm Motherboard Replacement
Wat je nodig hebt
  1. LG Realm Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 LG Realm Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Realm Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Realm Motherboard Replacement, Plastic Midframe: stap 3, afbeelding 1 van 2 LG Realm Motherboard Replacement, Plastic Midframe: stap 3, afbeelding 2 van 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
    Vraag FixBot
    Voeg opmerking toe
  4. LG Realm Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Realm Motherboard Replacement, Rear Facing Camera: stap 5, afbeelding 1 van 1
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. LG Realm Motherboard Replacement: stap 6, afbeelding 1 van 1
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
    Vraag FixBot
    Voeg opmerking toe
  7. LG Realm Motherboard Replacement, Front Facing Camera: stap 7, afbeelding 1 van 1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. LG Realm Motherboard Replacement: stap 8, afbeelding 1 van 1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  9. LG Realm Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  10. LG Realm Motherboard Replacement: stap 10, afbeelding 1 van 2 LG Realm Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
    Vraag FixBot
    Voeg opmerking toe
  11. LG Realm Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. LG Realm Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Using the plastic opening tool, carefully remove the motherboard from the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ryan St Martin
785 Reputatie
4 handleidingen geschreven
Marist, Team 1-5, Laflen Spring 2016 Lid van Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 37
Altijd: 1,576
