Ga door naar hoofdinhoud
LG Phoenix 2 Charge Port Replacement
Wat je nodig hebt
  1. LG Phoenix 2 Charge Port Replacement, Battery: stap 1, afbeelding 1 van 3 LG Phoenix 2 Charge Port Replacement, Battery: stap 1, afbeelding 2 van 3 LG Phoenix 2 Charge Port Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Charge Port Replacement: stap 2, afbeelding 1 van 3 LG Phoenix 2 Charge Port Replacement: stap 2, afbeelding 2 van 3 LG Phoenix 2 Charge Port Replacement: stap 2, afbeelding 3 van 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Charge Port Replacement, Motherboard: stap 3, afbeelding 1 van 2 LG Phoenix 2 Charge Port Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Charge Port Replacement: stap 4, afbeelding 1 van 2 LG Phoenix 2 Charge Port Replacement: stap 4, afbeelding 2 van 2
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Charge Port Replacement: stap 5, afbeelding 1 van 3 LG Phoenix 2 Charge Port Replacement: stap 5, afbeelding 2 van 3 LG Phoenix 2 Charge Port Replacement: stap 5, afbeelding 3 van 3
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Charge Port Replacement: stap 6, afbeelding 1 van 3 LG Phoenix 2 Charge Port Replacement: stap 6, afbeelding 2 van 3 LG Phoenix 2 Charge Port Replacement: stap 6, afbeelding 3 van 3
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
  7. LG Phoenix 2 Charge Port Replacement, Charge Port: stap 7, afbeelding 1 van 2 LG Phoenix 2 Charge Port Replacement, Charge Port: stap 7, afbeelding 2 van 2
  8. LG Phoenix 2 Charge Port Replacement: stap 8, afbeelding 1 van 3 LG Phoenix 2 Charge Port Replacement: stap 8, afbeelding 2 van 3 LG Phoenix 2 Charge Port Replacement: stap 8, afbeelding 3 van 3
    • Desolder the USB port from the motherboard and remove it from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alex Selsley
325 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G1, Harley Fall 2019 Lid van IUPUI, Team S1-G1, Harley Fall 2019
IUPUI-HARLEY-F19S1G1
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 686
