Ga door naar hoofdinhoud
LG Optimus G Pro Midframe Replacement
Wat je nodig hebt
  1. LG Optimus G Pro Midframe Replacement, Remove Back Cover.: stap 1, afbeelding 1 van 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Optimus G Pro Midframe Replacement, Remove the Battery.: stap 2, afbeelding 1 van 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Optimus G Pro Midframe Replacement, Screw Removal: stap 3, afbeelding 1 van 2 LG Optimus G Pro Midframe Replacement, Screw Removal: stap 3, afbeelding 2 van 2
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
    Vraag FixBot
    Voeg opmerking toe
  4. LG Optimus G Pro Midframe Replacement, Remove Cover: stap 4, afbeelding 1 van 1
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Optimus G Pro Midframe Replacement, Completion: stap 5, afbeelding 1 van 1
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wesley Pate
1.641 Reputatie
7 handleidingen geschreven
USF Tampa, Team 15-5, Remmell Fall 2014 Lid van USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 2,302
