Ga door naar hoofdinhoud
LG Optimus 3D MicroSD/SIM Card Board Replacement
Wat je nodig hebt
    1. LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: stap 1, afbeelding 1 van 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: stap 1, afbeelding 2 van 2
      • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: stap 2, afbeelding 1 van 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: stap 2, afbeelding 2 van 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: stap 2, afbeelding 3 van 3
      • The battery is the large black rectangle towards the bottom half of the phone.
      • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: stap 3, afbeelding 1 van 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: stap 3, afbeelding 2 van 2
      • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
      • 5.5mm length PH00 screws
      • 4mm length PH00 screws
      Vraag FixBot
      Voeg opmerking toe
    2. LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: stap 4, afbeelding 1 van 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: stap 4, afbeelding 2 van 2
      • Gently pull down on the bottom cover to remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: stap 5, afbeelding 1 van 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: stap 5, afbeelding 2 van 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: stap 5, afbeelding 3 van 3
      • Using a plastic opening tool, gently pry around the perimeter of the device.
      • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
      • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: stap 6, afbeelding 1 van 2 LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: stap 6, afbeelding 2 van 2
      • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Optimus 3D MicroSD/SIM Card Board Replacement, Adhesive Loosening: stap 7, afbeelding 1 van 1
      • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
      • Evenly heat the device in short intervals for about one minute.
      • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
      Vraag FixBot
      Voeg opmerking toe
    6. LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: stap 8, afbeelding 1 van 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: stap 8, afbeelding 2 van 3 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: stap 8, afbeelding 3 van 3
      • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
      • If the board is too difficult to separate than more heating may be required.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Dale Pearson
784 Reputatie
6 handleidingen geschreven
USF Tampa, Team 10-6, Brown Fall 2014 Lid van USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 44
Altijd: 1,397
