Ga door naar hoofdinhoud
LG LX160 Back Casing Replacement
Wat je nodig hebt
    1. LG LX160 Back Casing Replacement, Battery: stap 1, afbeelding 1 van 1
      • Place the phone on a flat surface with the back facing upward.
      • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
      Vraag FixBot
      Voeg opmerking toe
    2. LG LX160 Back Casing Replacement: stap 2, afbeelding 1 van 1
      • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. LG LX160 Back Casing Replacement: stap 3, afbeelding 1 van 1
      • Remove the battery completely from the phone and place the battery off to the side.
      Vraag FixBot
      Voeg opmerking toe
    1. LG LX160 Back Casing Replacement, Back Casing: stap 4, afbeelding 1 van 1
      • Now that the battery has been completely removed, hold the phone upright.
      • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
      Vraag FixBot
      Voeg opmerking toe
    2. LG LX160 Back Casing Replacement: stap 5, afbeelding 1 van 1
      • Flip the phone with the backside facing up.
      • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
      Vraag FixBot
      Voeg opmerking toe
    3. LG LX160 Back Casing Replacement: stap 6, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
      • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Shane Smith
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-2, Forte Winter 2010 Lid van Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Leden
35 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 2,331
