Ga door naar hoofdinhoud
LG L1200 Inner LCD Screen Replacement
Wat je nodig hebt
    1. LG L1200 Inner LCD Screen Replacement, Inner LCD Screen: stap 1, afbeelding 1 van 1
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Flip open the phone and locate the four screw covers.
      Vraag FixBot
      Voeg opmerking toe
    2. LG L1200 Inner LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
      Vraag FixBot
      Voeg opmerking toe
    3. LG L1200 Inner LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • Using a T6 Torx screwdriver, remove all four screws.
      Vraag FixBot
      Voeg opmerking toe
    4. LG L1200 Inner LCD Screen Replacement: stap 4, afbeelding 1 van 3 LG L1200 Inner LCD Screen Replacement: stap 4, afbeelding 2 van 3 LG L1200 Inner LCD Screen Replacement: stap 4, afbeelding 3 van 3
      • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
      • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
      Vraag FixBot
      Voeg opmerking toe
    5. LG L1200 Inner LCD Screen Replacement: stap 5, afbeelding 1 van 2 LG L1200 Inner LCD Screen Replacement: stap 5, afbeelding 2 van 2
      • Pull the inner screen cover towards you and up in order to separate it from the front cover.
      Vraag FixBot
      Voeg opmerking toe
    6. LG L1200 Inner LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Remove the tape from the bottom of the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    7. LG L1200 Inner LCD Screen Replacement: stap 7, afbeelding 1 van 3 LG L1200 Inner LCD Screen Replacement: stap 7, afbeelding 2 van 3 LG L1200 Inner LCD Screen Replacement: stap 7, afbeelding 3 van 3
      • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    8. LG L1200 Inner LCD Screen Replacement: stap 8, afbeelding 1 van 3 LG L1200 Inner LCD Screen Replacement: stap 8, afbeelding 2 van 3 LG L1200 Inner LCD Screen Replacement: stap 8, afbeelding 3 van 3
      • Flip the screen over so that you can see the outer LCD screen and the circuit board.
      • Insert spudger in the bottom right corner.
      • Lift up and move the spudger across the bottom.
      • The third photo is rotated 180 degrees.
      Vraag FixBot
      Voeg opmerking toe
    9. LG L1200 Inner LCD Screen Replacement: stap 9, afbeelding 1 van 2 LG L1200 Inner LCD Screen Replacement: stap 9, afbeelding 2 van 2
      • Use the pointy side of the spudger to peel off the interior tape.
      • Flip the assembly over and peel the circuit board from the screen.
      Vraag FixBot
      Voeg opmerking toe
    10. LG L1200 Inner LCD Screen Replacement: stap 10, afbeelding 1 van 2 LG L1200 Inner LCD Screen Replacement: stap 10, afbeelding 2 van 2
      • Use the spudger to remove the LCD screen from its backing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Joshua Herrmann
8 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-14, Maness Spring 2010 Lid van Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 2,585
