Ga door naar hoofdinhoud
LG K7 T-Mobile Rear Phone Camera Replacement
Wat je nodig hebt
  1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: stap 1, afbeelding 1 van 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  4. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: stap 4, afbeelding 1 van 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: stap 4, afbeelding 2 van 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  5. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 5, afbeelding 1 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 5, afbeelding 2 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 5, afbeelding 3 van 3
    • Turn the phone over so the screen is facing up
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
    Vraag FixBot
    Voeg opmerking toe
  6. LG K7 T-Mobile Rear Phone  Camera Replacement: stap 6, afbeelding 1 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 6, afbeelding 2 van 3 LG K7 T-Mobile Rear Phone  Camera Replacement: stap 6, afbeelding 3 van 3
    • Locate the ribbon cable that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Salem Jean
216 Reputatie
1 Handleiding geschreven
USF Tampa, Team S2-G5, Nance Fall 2017 Lid van USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 788
