Ga door naar hoofdinhoud
LG K4 Battery Replacement
Wat je nodig hebt
  1. LG K4 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • First, turn off the phone to prevent any electrical issues or possible storage loss.
  2. LG K4 Battery Replacement: stap 2, afbeelding 1 van 2 LG K4 Battery Replacement: stap 2, afbeelding 2 van 2
    • Open the back of the phone carefully. You can use your hands or any plastic opener tools; simply stick one nail (or plastic opener) on the tiny dent shown and carefully pull it out.
    • There are many ways to remove the back cover. The best way is to use this tiny dent on the side to avoid any cracks.
  3. LG K4 Battery Replacement: stap 3, afbeelding 1 van 3 LG K4 Battery Replacement: stap 3, afbeelding 2 van 3 LG K4 Battery Replacement: stap 3, afbeelding 3 van 3
    • Once you remove the back cover, remove the old battery from the back of the phone by grabbing the lower part of the battery as shown in the picture. Once you do this leave the battery aside.
  4. LG K4 Battery Replacement: stap 4, afbeelding 1 van 2 LG K4 Battery Replacement: stap 4, afbeelding 2 van 2
    • Install the new battery. First, slide it up to where the four pins are located.
    • Make sure to do it properly by looking at the positive and negative symbols.
  5. LG K4 Battery Replacement: stap 5, afbeelding 1 van 2 LG K4 Battery Replacement: stap 5, afbeelding 2 van 2
    • Reattach the back cover, make sure the headphone jack, charging port and volume buttons all fit with the cover.
    • When reattaching the cover, make sure to leave no spaces between the phone and the cover. This could be a potential danger to your phone since things like dust or water are easier to get in.
  6. LG K4 Battery Replacement: stap 6, afbeelding 1 van 1
    • Turn on the phone and check if the battery charges too. This step is important to check if the battery was properly placed or functions properly.
    • If for some reason the phone does not turn on, give it some time to charge completely. If given this time the phone still doesn't turn on, you may need to get a new battery and follow the guide all over again.
Conclusie
To reassemble your device, follow instructions 6 to 2 in reverse order.
Said Ramos
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 196
