Ga door naar hoofdinhoud
LG K30 Battery Replacement
Wat je nodig hebt
    1. LG K30 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 LG K30 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
      • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your Phone before beginning disassembly.
      • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
      Vraag FixBot
      Voeg opmerking toe
    2. LG K30 Battery Replacement: stap 2, afbeelding 1 van 1
      • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      Vraag FixBot
      Voeg opmerking toe
    3. LG K30 Battery Replacement: stap 3, afbeelding 1 van 1
      • Use a metal spudger or plastic opening tool to pry open the outer cover.
      Vraag FixBot
      Voeg opmerking toe
    4. LG K30 Battery Replacement: stap 4, afbeelding 1 van 1
      • Use the flat end of a spudger to detach the battery connector from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    5. LG K30 Battery Replacement: stap 5, afbeelding 1 van 2 LG K30 Battery Replacement: stap 5, afbeelding 2 van 2
      • Use a spudger to pry the battery from the phone.
      • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
      • Do not bend or puncture the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
There's no description of removing the display or supporting it. Why is an LG K30 screen with frame required?
P Schmied - Antwoord Deel
thank you it really meant a lot
Albert E - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 56
Altijd: 14,253
