Ga door naar hoofdinhoud
LG Intuition Screen Protector Replacement
Wat je nodig hebt
  1. LG Intuition Screen Protector Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device so the two bottom screws are shown.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Intuition Screen Protector Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Intuition Screen Protector Replacement: stap 3, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
    Vraag FixBot
    Voeg opmerking toe
  4. LG Intuition Screen Protector Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Intuition Screen Protector Replacement: stap 5, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. LG Intuition Screen Protector Replacement: stap 6, afbeelding 1 van 2 LG Intuition Screen Protector Replacement: stap 6, afbeelding 2 van 2
    • Gently raise the battery from its compartment.
    Vraag FixBot
    Voeg opmerking toe
  7. LG Intuition Screen Protector Replacement, Plastic Motherboard Shield: stap 7, afbeelding 1 van 1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. LG Intuition Screen Protector Replacement: stap 8, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
    Vraag FixBot
    Voeg opmerking toe
  9. LG Intuition Screen Protector Replacement, Camera: stap 9, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. LG Intuition Screen Protector Replacement: stap 10, afbeelding 1 van 1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
    Vraag FixBot
    Voeg opmerking toe
  11. LG Intuition Screen Protector Replacement, Volume Buttons: stap 11, afbeelding 1 van 2 LG Intuition Screen Protector Replacement, Volume Buttons: stap 11, afbeelding 2 van 2
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
    Vraag FixBot
    Voeg opmerking toe
  12. LG Intuition Screen Protector Replacement, Screen Protector: stap 12, afbeelding 1 van 2 LG Intuition Screen Protector Replacement, Screen Protector: stap 12, afbeelding 2 van 2
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
    Vraag FixBot
    Voeg opmerking toe
  13. LG Intuition Screen Protector Replacement: stap 13, afbeelding 1 van 2 LG Intuition Screen Protector Replacement: stap 13, afbeelding 2 van 2
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
    Vraag FixBot
    Voeg opmerking toe
  14. LG Intuition Screen Protector Replacement: stap 14, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
    Vraag FixBot
    Voeg opmerking toe
  15. LG Intuition Screen Protector Replacement: stap 15, afbeelding 1 van 2 LG Intuition Screen Protector Replacement: stap 15, afbeelding 2 van 2
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
    Vraag FixBot
    Voeg opmerking toe
  16. LG Intuition Screen Protector Replacement: stap 16, afbeelding 1 van 1
    • Carefully pull the ribbon cable upward and away from the front screen display.
    Vraag FixBot
    Voeg opmerking toe
  17. LG Intuition Screen Protector Replacement: stap 17, afbeelding 1 van 1
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
    Vraag FixBot
    Voeg opmerking toe
  18. LG Intuition Screen Protector Replacement: stap 18, afbeelding 1 van 2 LG Intuition Screen Protector Replacement: stap 18, afbeelding 2 van 2
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Thomas Morrissey
616 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
3 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 462
