Ga door naar hoofdinhoud
LG Incite Touch Screen Replacement
Wat je nodig hebt
  1. LG Incite Touch Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Hold the phone camera-side up and locate the rear cover.
    Vraag FixBot
    Voeg opmerking toe
  2. LG Incite Touch Screen Replacement: stap 2, afbeelding 1 van 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. LG Incite Touch Screen Replacement: stap 3, afbeelding 1 van 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
    Vraag FixBot
    Voeg opmerking toe
  4. LG Incite Touch Screen Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  5. LG Incite Touch Screen Replacement: stap 5, afbeelding 1 van 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
    Vraag FixBot
    Voeg opmerking toe
  6. LG Incite Touch Screen Replacement: stap 6, afbeelding 1 van 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
    Vraag FixBot
    Voeg opmerking toe
  7. LG Incite Touch Screen Replacement, Motherboard: stap 7, afbeelding 1 van 3 LG Incite Touch Screen Replacement, Motherboard: stap 7, afbeelding 2 van 3 LG Incite Touch Screen Replacement, Motherboard: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
    • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
    • Repeat this for the white tab on the opposite side of the phone.
    • This tab also has two plastic bases adhering it to the edge of the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. LG Incite Touch Screen Replacement: stap 8, afbeelding 1 van 1
    • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
    • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
    Vraag FixBot
    Voeg opmerking toe
  9. LG Incite Touch Screen Replacement: stap 9, afbeelding 1 van 2 LG Incite Touch Screen Replacement: stap 9, afbeelding 2 van 2
    • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
    • Do not remove the tab completely, it should still be connected to the phone.
    Vraag FixBot
    Voeg opmerking toe
  10. LG Incite Touch Screen Replacement: stap 10, afbeelding 1 van 1
    • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
    • Lift the motherboard and slide it towards you by hand to free it from the phone.
    • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
    Vraag FixBot
    Voeg opmerking toe
  11. LG Incite Touch Screen Replacement, Touch Screen: stap 11, afbeelding 1 van 1
    • Remove the call and end buttons using the metal tweezers.
    Vraag FixBot
    Voeg opmerking toe
  12. LG Incite Touch Screen Replacement: stap 12, afbeelding 1 van 1
    • Wedge the plastic opening tool between the screen and sides of the phone.
    • Slide the tool along the edge to loosen the screen.
    • Repeat for the opposite side.
    • Don't completely remove the screen yet to avoid damaging the screen.
    Vraag FixBot
    Voeg opmerking toe
  13. LG Incite Touch Screen Replacement: stap 13, afbeelding 1 van 1
    • Wedge the plastic opening tool under the screen where the buttons were to loosen it.
    Vraag FixBot
    Voeg opmerking toe
  14. LG Incite Touch Screen Replacement: stap 14, afbeelding 1 van 2 LG Incite Touch Screen Replacement: stap 14, afbeelding 2 van 2
    • Gently peel the touch screen off from the bottom of the phone.
    • Do not damage the yellow tab in the upper right corner of the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kimberly Kha
163 Reputatie
5 handleidingen geschreven
Cal Poly, Team 2-18, Maness Spring 2013 Lid van Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 50
Altijd: 1,559
