Ga door naar hoofdinhoud
LG Incite Back Panel Replacement
Wat je nodig hebt
    1. LG Incite Back Panel Replacement, Battery: stap 1, afbeelding 1 van 1
      • Hold the phone camera-side up and locate the rear cover.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Incite Back Panel Replacement: stap 2, afbeelding 1 van 1
      • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Incite Back Panel Replacement: stap 3, afbeelding 1 van 1
      • Place the plastic opening tool in the small slot below and to the left of the battery.
      • Pry the battery upward to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Incite Back Panel Replacement, Back Panel: stap 4, afbeelding 1 van 1
      • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Incite Back Panel Replacement: stap 5, afbeelding 1 van 1
      • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
      • Gently move the tool around the perimeter of the screen to separate it from the body.
      • You should not completely separate the screen from the device in this step.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Incite Back Panel Replacement: stap 6, afbeelding 1 van 1
      • Flip the device over so the battery compartment faces up.
      • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
      • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
      • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kimberly Kha
163 Reputatie
5 handleidingen geschreven
Cal Poly, Team 2-18, Maness Spring 2013 Lid van Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 1,037
