Ga door naar hoofdinhoud
LG G8 ThinQ Front Cameras Replacement
Wat je nodig hebt
  1. LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: stap 1, afbeelding 1 van 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: stap 1, afbeelding 2 van 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: stap 1, afbeelding 3 van 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Front Cameras Replacement, Back Panel: stap 2, afbeelding 1 van 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: stap 2, afbeelding 2 van 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: stap 2, afbeelding 3 van 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Front Cameras Replacement, Midframe: stap 3, afbeelding 1 van 3 LG G8 ThinQ Front Cameras Replacement, Midframe: stap 3, afbeelding 2 van 3 LG G8 ThinQ Front Cameras Replacement, Midframe: stap 3, afbeelding 3 van 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Front Cameras Replacement, Front Cameras: stap 4, afbeelding 1 van 2 LG G8 ThinQ Front Cameras Replacement, Front Cameras: stap 4, afbeelding 2 van 2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  5. LG G8 ThinQ Front Cameras Replacement: stap 5, afbeelding 1 van 3 LG G8 ThinQ Front Cameras Replacement: stap 5, afbeelding 2 van 3 LG G8 ThinQ Front Cameras Replacement: stap 5, afbeelding 3 van 3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Josh Cress
473 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 479
