Ga door naar hoofdinhoud
LG G8 ThinQ Battery Replacement
Wat je nodig hebt
  1. LG G8 ThinQ Battery Replacement, SIM Card Tray: stap 1, afbeelding 1 van 3 LG G8 ThinQ Battery Replacement, SIM Card Tray: stap 1, afbeelding 2 van 3 LG G8 ThinQ Battery Replacement, SIM Card Tray: stap 1, afbeelding 3 van 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Battery Replacement, Back Panel: stap 2, afbeelding 1 van 3 LG G8 ThinQ Battery Replacement, Back Panel: stap 2, afbeelding 2 van 3 LG G8 ThinQ Battery Replacement, Back Panel: stap 2, afbeelding 3 van 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
    This is where I started to ponder for the first time because my camera looks different.
    I also have a LG G8 ThinQ but maybe the european version
    Thomas Wiele - Antwoord
  3. LG G8 ThinQ Battery Replacement, Midframe: stap 3, afbeelding 1 van 3 LG G8 ThinQ Battery Replacement, Midframe: stap 3, afbeelding 2 van 3 LG G8 ThinQ Battery Replacement, Midframe: stap 3, afbeelding 3 van 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
    and here it is true, the screws are in a different place. The sound system on the bottom is also different
  4. LG G8 ThinQ Battery Replacement, Speaker System: stap 4, afbeelding 1 van 3 LG G8 ThinQ Battery Replacement, Speaker System: stap 4, afbeelding 2 van 3 LG G8 ThinQ Battery Replacement, Speaker System: stap 4, afbeelding 3 van 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  6. LG G8 ThinQ Battery Replacement: stap 6, afbeelding 1 van 2 LG G8 ThinQ Battery Replacement: stap 6, afbeelding 2 van 2
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
    the battery type of my LG is "BL-T43"
  7. LG G8 ThinQ Battery Replacement: stap 7, afbeelding 1 van 3 LG G8 ThinQ Battery Replacement: stap 7, afbeelding 2 van 3 LG G8 ThinQ Battery Replacement: stap 7, afbeelding 3 van 3
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
    Although it is a different phone, the instructions were helpful.
    Unfortunately, my battery exchange was pointless.
    I think my USB socket is defective and unfortunately I can't find any instructions for it at the moment.
    But if anybody want, i can send a few pics from the repairing
Conclusie
6 andere personen hebben deze handleiding voltooid.
5 opmerkingen
You don't use any heat to remove the back glass panel? Just suction cup and prying?
CarnalT - Antwoord
Yep need heat to remove the back. Glass shattered on mine. Ifixit needs to fix this guide.
Bryan Ransom - Antwoord
Success! I documented the process using ifixit tools on https://waynedavis.com
Wayne Davis - Antwoord
thanks for your tutorial man it helped me a lot
John Eric Limbago -
Very helpful tutorials guys. Im in need of replacing my battery in my g8. 2 questions. Do you need to remove the speaker component at the bottom left in order to replace the battery? Some videos i watched they didnt remove it. 2nd question is how to i get the back cover back on after replacing the battery? Is there a specific adhesive i can get?
Johnny XRay - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 205
Altijd: 10,558
