Ga door naar hoofdinhoud
LG G7 ThinQ Speaker System Replacement
Wat je nodig hebt
  1. LG G7 ThinQ Speaker System Replacement, SIM Card: stap 1, afbeelding 1 van 1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 ThinQ Speaker System Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
  3. LG G7 ThinQ Speaker System Replacement, Speaker System: stap 3, afbeelding 1 van 1
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
  4. LG G7 ThinQ Speaker System Replacement, Remove the speaker system: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use your fingers or tweezers to remove the speaker system.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 776
