Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace the battery on your LG G6.
Wat je nodig hebt
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
14 andere personen hebben deze handleiding voltooid.
7 opmerkingen
I found this article while searching for info on battery replacement. I’m considering purchasing this phone. I’m wondering if opening the back would wreck the waterproof rating.
Yes, opening the back does remove the water sealant that is factory installed. You might be able to find the replacement “glue” that gives the phone the water proof rating but I’m not sure I would really trust it. Probably easier to just be really careful near liquids after the battery replacement. I’m looking at battery replacement in the next few months and that is my plan anyway, just keep the phone away from liquids like I’ve always tried to do with every phone I’ve owned.
I also need to know.
I replaced the thermal paste, battery, USB port, and sim card tray. The Sim tray broke internally upon removal. Hopefully no pins were bent in the process. Everything else went together pretty well. The rear adhesive may be reusable but I would not recommend it. The precut adhesive I used I am not fond of and may have to redo the seal with some double-sided tape.
