Ga door naar hoofdinhoud
LG G5 Rear Camera Replacement
Wat je nodig hebt
  1. LG G5 Rear Camera Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 2 LG G5 Rear Camera Replacement, Front Panel Assembly: stap 1, afbeelding 2 van 2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Rear Camera Replacement: stap 2, afbeelding 1 van 3 LG G5 Rear Camera Replacement: stap 2, afbeelding 2 van 3 LG G5 Rear Camera Replacement: stap 2, afbeelding 3 van 3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Rear Camera Replacement: stap 3, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    Holy this step is hard
    Nickstar - Antwoord
    It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
    ayeeeee -
  5. LG G5 Rear Camera Replacement: stap 5, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    My LCD started to let loose using this way to saparate the top and bottom of the phone.
    I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
    Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
    Ray Bas - Antwoord
    Yep! I did it also with this method. Wayy better and easier ;)
    ronlad.garud -
    My screen cracked taking it out following ifixit method . Right when I got to the part where it starts to curve at the top. Just shattered.
    Randy - Antwoord
    I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
    Arthur Heller - Antwoord
  6. LG G5 Rear Camera Replacement: stap 6, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Peel the screen away from the body. The two parts should be completely separated.
  7. LG G5 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 1 van 3 LG G5 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 2 van 3 LG G5 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 3 van 3
    • Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
  8. LG G5 Rear Camera Replacement: stap 8, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • After detaching the ribbon, carefully remove the camera using tweezers
    The camera is attached to the frame with adhesive- use a nylon screen opening tool or a spludger to help lift the camera off of the body. Tilt it out at a 45 degree angle to clear the PCB and you're ready for replacement!
    Camden Stensland - Antwoord
    I found it easier to use some guitar picks to separate the screen from the body. I lifted the screen away from the body using a prying tool, then insert the guitar pick in the gap. I worked it along the seam until I got to the top of the phone, then worked on the other side.
    James Arthurs - Antwoord
Conclusie
34 andere personen hebben deze handleiding voltooid.
Parker Reynolds
935 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-2, Forte Fall 2016 Lid van Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Leden
15 handleidingen geschreven
6 opmerkingen
This worked great and took me about 10 minutes!
Mark - Antwoord
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
Christopher Piatt - Antwoord
the camera is held down with sticky tape and I wasn’t comfortable pulling hard under the processing board, so I pulled the six screws holding that down and removed it first. Unfortunately for me the new camera still doesn’t focus…
Ray White - Antwoord
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
Brad - Antwoord
You may want to mention that the original camera is glued in. It takes a bit of prying to pop it out.
Ryan - Antwoord
I can’t pry the screen off with the plastic tools I purchased with ifixit. what now?
Suzanne Artzberger - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 17,300
