Ga door naar hoofdinhoud
LG G5 Rear Camera Replacement
Wat je nodig hebt
  1. LG G5 Rear Camera Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 2 LG G5 Rear Camera Replacement, Front Panel Assembly: stap 1, afbeelding 2 van 2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    Vraag FixBot
    Voeg opmerking toe
  2. LG G5 Rear Camera Replacement: stap 2, afbeelding 1 van 3 LG G5 Rear Camera Replacement: stap 2, afbeelding 2 van 3 LG G5 Rear Camera Replacement: stap 2, afbeelding 3 van 3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. LG G5 Rear Camera Replacement: stap 3, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. LG G5 Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    Vraag FixBot
    Voeg opmerking toe
  5. LG G5 Rear Camera Replacement: stap 5, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    Vraag FixBot
    Voeg opmerking toe
  6. LG G5 Rear Camera Replacement: stap 6, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Peel the screen away from the body. The two parts should be completely separated.
    Vraag FixBot
    Voeg opmerking toe
  7. LG G5 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 1 van 3 LG G5 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 2 van 3 LG G5 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 3 van 3
    • Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
    Vraag FixBot
    Voeg opmerking toe
  8. LG G5 Rear Camera Replacement: stap 8, afbeelding 1 van 2 LG G5 Rear Camera Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • After detaching the ribbon, carefully remove the camera using tweezers
    Vraag FixBot
    Voeg opmerking toe
Conclusie
34 andere personen hebben deze handleiding voltooid.
Parker Reynolds
937 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-2, Forte Fall 2016 Lid van Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Leden
27 handleidingen geschreven
6Gids Commentaar
This worked great and took me about 10 minutes!
Mark - Antwoord Deel
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
Christopher Piatt - Antwoord Deel
the camera is held down with sticky tape and I wasn’t comfortable pulling hard under the processing board, so I pulled the six screws holding that down and removed it first. Unfortunately for me the new camera still doesn’t focus…
Ray White - Antwoord Deel
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
Brad - Antwoord Deel
You may want to mention that the original camera is glued in. It takes a bit of prying to pop it out.
Ryan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 55
Altijd: 18,108
