Ga door naar hoofdinhoud
LG G3 Rear Facing Camera Replacement
Wat je nodig hebt
  1. LG G3 Rear Facing Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    Vraag FixBot
    Voeg opmerking toe
  2. LG G3 Rear Facing Camera Replacement: stap 2, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. LG G3 Rear Facing Camera Replacement, Battery: stap 3, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    Vraag FixBot
    Voeg opmerking toe
  4. LG G3 Rear Facing Camera Replacement: stap 4, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery out of its recess and remove it.
    Vraag FixBot
    Voeg opmerking toe
  5. LG G3 Rear Facing Camera Replacement, Loudspeaker: stap 5, afbeelding 1 van 1
    • Remove the four Phillips #00 screws (4 mm length).
    Vraag FixBot
    Voeg opmerking toe
  6. LG G3 Rear Facing Camera Replacement: stap 6, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    Vraag FixBot
    Voeg opmerking toe
  7. LG G3 Rear Facing Camera Replacement: stap 7, afbeelding 1 van 3 LG G3 Rear Facing Camera Replacement: stap 7, afbeelding 2 van 3 LG G3 Rear Facing Camera Replacement: stap 7, afbeelding 3 van 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    Vraag FixBot
    Voeg opmerking toe
  8. LG G3 Rear Facing Camera Replacement, Motherboard Cover Assembly: stap 8, afbeelding 1 van 1
    • Remove the eight Phillips #00 screws (4 mm length).
    Vraag FixBot
    Voeg opmerking toe
  9. LG G3 Rear Facing Camera Replacement: stap 9, afbeelding 1 van 3 LG G3 Rear Facing Camera Replacement: stap 9, afbeelding 2 van 3 LG G3 Rear Facing Camera Replacement: stap 9, afbeelding 3 van 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
    Vraag FixBot
    Voeg opmerking toe
  10. LG G3 Rear Facing Camera Replacement: stap 10, afbeelding 1 van 3 LG G3 Rear Facing Camera Replacement: stap 10, afbeelding 2 van 3 LG G3 Rear Facing Camera Replacement: stap 10, afbeelding 3 van 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  11. LG G3 Rear Facing Camera Replacement, Motherboard: stap 11, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement, Motherboard: stap 11, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the display flex cable.
    Vraag FixBot
    Voeg opmerking toe
  12. LG G3 Rear Facing Camera Replacement: stap 12, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 12, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
    Vraag FixBot
    Voeg opmerking toe
  13. LG G3 Rear Facing Camera Replacement: stap 13, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 13, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
    Vraag FixBot
    Voeg opmerking toe
  14. LG G3 Rear Facing Camera Replacement: stap 14, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 14, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the front camera flex cable.
    Vraag FixBot
    Voeg opmerking toe
  15. LG G3 Rear Facing Camera Replacement: stap 15, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 15, afbeelding 2 van 2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
    Vraag FixBot
    Voeg opmerking toe
  16. LG G3 Rear Facing Camera Replacement: stap 16, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 16, afbeelding 2 van 2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
    Vraag FixBot
    Voeg opmerking toe
  17. LG G3 Rear Facing Camera Replacement: stap 17, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement: stap 17, afbeelding 2 van 2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  18. LG G3 Rear Facing Camera Replacement, Rear Facing Camera: stap 18, afbeelding 1 van 2 LG G3 Rear Facing Camera Replacement, Rear Facing Camera: stap 18, afbeelding 2 van 2
    • Take the plastic opening tool and remove the rear-facing camera by wedging it into the sides and lifting up
    • The rear-facing camera is kept in place with a double-sided tape, so it may take some time and effort to get it out. Attack it from all sides
    Vraag FixBot
    Voeg opmerking toe
  19. LG G3 Rear Facing Camera Replacement: stap 19, afbeelding 1 van 1
    • Remove the old rear-facing camera
    Vraag FixBot
    Voeg opmerking toe
Conclusie
26 andere personen hebben deze handleiding voltooid.
Shannon
1.613 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-3, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-3, Duarte Fall 2014
UMASSD-DUARTE-F14S1G3
4 Leden
21 handleidingen geschreven
7Gids Commentaar
perfect. Camera had stopped functioning on my G3 (due to some clumsiness on my part). Followed the steps and disconnect camera ribbon, then reconnected and reassembled. Now all functioning perfectly.
Andy Corps - Antwoord Deel
how was it not functioning? Mine suddenly wont even detect that there is a back camera and I am debating whether to try this and risk ruining the phone or just spending the extra cash and having it done professionally since I can't get a new one until april.
Claire Robbins - Antwoord Deel
Mine the camera started crashing 'unfortunately camera stopped' but the selfie cam worked. Reset did nothing have to try this.
Gad Mugane - Antwoord Deel
Will the phone work with out the camera in it?
Mike Kizer - Antwoord Deel
Excellent guide.    Bad auto focus, replaced -> works !
Would add in step 6, top panel is held on by small plastic tabs on the edges.
As with all electronic dis/assembly, make sure take appropriate anti-static precautions.
Jonathan Ling - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 21,225
