Ga door naar hoofdinhoud
LG G3 Power & Volume Button Cable Replacement
Wat je nodig hebt
  1. LG G3 Power & Volume Button Cable Replacement, Back Cover: stap 1, afbeelding 1 van 2 LG G3 Power & Volume Button Cable Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    Vraag FixBot
    Voeg opmerking toe
  2. LG G3 Power & Volume Button Cable Replacement: stap 2, afbeelding 1 van 2 LG G3 Power & Volume Button Cable Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. LG G3 Power & Volume Button Cable Replacement, Battery: stap 3, afbeelding 1 van 2 LG G3 Power & Volume Button Cable Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    Vraag FixBot
    Voeg opmerking toe
  4. LG G3 Power & Volume Button Cable Replacement: stap 4, afbeelding 1 van 2 LG G3 Power & Volume Button Cable Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery out of its recess and remove it.
    Vraag FixBot
    Voeg opmerking toe
  5. LG G3 Power & Volume Button Cable Replacement, Loudspeaker: stap 5, afbeelding 1 van 1
    • Remove the four Phillips #00 screws (4 mm length).
    Vraag FixBot
    Voeg opmerking toe
  6. LG G3 Power & Volume Button Cable Replacement: stap 6, afbeelding 1 van 2 LG G3 Power & Volume Button Cable Replacement: stap 6, afbeelding 2 van 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    Vraag FixBot
    Voeg opmerking toe
  7. LG G3 Power & Volume Button Cable Replacement: stap 7, afbeelding 1 van 3 LG G3 Power & Volume Button Cable Replacement: stap 7, afbeelding 2 van 3 LG G3 Power & Volume Button Cable Replacement: stap 7, afbeelding 3 van 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    Vraag FixBot
    Voeg opmerking toe
  8. LG G3 Power & Volume Button Cable Replacement, Motherboard Cover Assembly: stap 8, afbeelding 1 van 1
    • Remove the eight Phillips #00 screws (4 mm length).
    Vraag FixBot
    Voeg opmerking toe
  9. LG G3 Power & Volume Button Cable Replacement: stap 9, afbeelding 1 van 3 LG G3 Power & Volume Button Cable Replacement: stap 9, afbeelding 2 van 3 LG G3 Power & Volume Button Cable Replacement: stap 9, afbeelding 3 van 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
    Vraag FixBot
    Voeg opmerking toe
  10. LG G3 Power & Volume Button Cable Replacement: stap 10, afbeelding 1 van 3 LG G3 Power & Volume Button Cable Replacement: stap 10, afbeelding 2 van 3 LG G3 Power & Volume Button Cable Replacement: stap 10, afbeelding 3 van 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  11. LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: stap 11, afbeelding 1 van 2 LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: stap 11, afbeelding 2 van 2
    • Remove the last screw attaching the rear camera lens to the frame.
    • Now use a plastic spudger to carefully remove the camera lens.
    Vraag FixBot
    Voeg opmerking toe
  12. LG G3 Power & Volume Button Cable Replacement: stap 12, afbeelding 1 van 3 LG G3 Power & Volume Button Cable Replacement: stap 12, afbeelding 2 van 3 LG G3 Power & Volume Button Cable Replacement: stap 12, afbeelding 3 van 3
    • Using the spudger, release power & volume button flex from adhesive carefully.
    Vraag FixBot
    Voeg opmerking toe
  13. LG G3 Power & Volume Button Cable Replacement: stap 13, afbeelding 1 van 1
    • Finally, remove the flex.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sophia
43.911 Reputatie
62 handleidingen geschreven
1Gids Commentaar
I bought a more powerful battery. 6800 mah .instead of the 3000mah OEM . Ia there any problem using it?
mitoll - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 22,709
