Ga door naar hoofdinhoud
LG G2 Sprint Display Assembly Replacement
Wat je nodig hebt
  1. LG G2 Sprint Display Assembly Replacement, Charger Port: stap 1, afbeelding 1 van 2 LG G2 Sprint Display Assembly Replacement, Charger Port: stap 1, afbeelding 2 van 2
    • Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
    • Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
    Vraag FixBot
    Voeg opmerking toe
  2. LG G2 Sprint Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • After removing the outer phone case, you will need two Phillips head bits. One J0 and one J000 size.
    • There are 11 silver screws for which you have to use J0 head bits, and 1 small black screw for which you have to use a J000 head bit.
    Vraag FixBot
    Voeg opmerking toe
  3. LG G2 Sprint Display Assembly Replacement: stap 3, afbeelding 1 van 3 LG G2 Sprint Display Assembly Replacement: stap 3, afbeelding 2 van 3 LG G2 Sprint Display Assembly Replacement: stap 3, afbeelding 3 van 3
    • There is a clip on the upper left side of the upper panel. Use the plastic opening tool to pry the clip off of the phone.
    • The upper inside panel flips up easily off of the phone case once all the clips and screws are removed. If the panel does not pull off easily, check that you have removed all of the screws.
    • There are ribbons that need to be removed as well. Be sure to carefully pry them off of the board
    Vraag FixBot
    Voeg opmerking toe
  4. LG G2 Sprint Display Assembly Replacement: stap 4, afbeelding 1 van 3 LG G2 Sprint Display Assembly Replacement: stap 4, afbeelding 2 van 3 LG G2 Sprint Display Assembly Replacement: stap 4, afbeelding 3 van 3
    • The bottom inside panel should pry back easily after you take out the screws. Again, if the panel does not pull off easily, you may have missed a screw.
    Vraag FixBot
    Voeg opmerking toe
  5. LG G2 Sprint Display Assembly Replacement: stap 5, afbeelding 1 van 3 LG G2 Sprint Display Assembly Replacement: stap 5, afbeelding 2 van 3 LG G2 Sprint Display Assembly Replacement: stap 5, afbeelding 3 van 3
    • There are several clips and circuits that need to be released. They are circled in the images above. Be careful not to break any of the attached ribbon or wires. (circle ribbons etc.)
    • Be careful to use your tools to disconnect the cables at the connectors and not along the wire.
    Vraag FixBot
    Voeg opmerking toe
  6. LG G2 Sprint Display Assembly Replacement: stap 6, afbeelding 1 van 3 LG G2 Sprint Display Assembly Replacement: stap 6, afbeelding 2 van 3 LG G2 Sprint Display Assembly Replacement: stap 6, afbeelding 3 van 3
    • The orange materials is meant to bend along the dotted line labeled “bend.” Try to make the bend as close to this line as possible.
    Vraag FixBot
    Voeg opmerking toe
  7. LG G2 Sprint Display Assembly Replacement: stap 7, afbeelding 1 van 3 LG G2 Sprint Display Assembly Replacement: stap 7, afbeelding 2 van 3 LG G2 Sprint Display Assembly Replacement: stap 7, afbeelding 3 van 3
    • After you have disconnected all of the ribbon and antennae connections, you can remove the board. Gently pry the board up from the bottom of the case and slide it back out.
    • Make sure to remove all ribbon connectors from the board prior to removing the board.
    Vraag FixBot
    Voeg opmerking toe
  8. LG G2 Sprint Display Assembly Replacement, Display Assembly: stap 8, afbeelding 1 van 2 LG G2 Sprint Display Assembly Replacement, Display Assembly: stap 8, afbeelding 2 van 2
    • Now you are ready to remove the battery. Make sure to adhere to ESD prevention guidelines, use a plastic tool as to not damage the battery.
    • Start at the top left of the battery and slide your nylon spudger under the battery. There is a layer of adhesive that keeps the battery in the case. Use steady, firm pressure to pull the battery up.
    • If the battery case begins to bend, you may need to use less force.
    Vraag FixBot
    Voeg opmerking toe
  9. LG G2 Sprint Display Assembly Replacement: stap 9, afbeelding 1 van 3 LG G2 Sprint Display Assembly Replacement: stap 9, afbeelding 2 van 3 LG G2 Sprint Display Assembly Replacement: stap 9, afbeelding 3 van 3
    • Removed the cables by pulling them out, they are held in by black tape.
    • The vibe motor is held in by a strong adhesive, use a slim tool to get underneath and remove.
    • The camera can be removed effortlessly by using a slim plastic tool to lift it out of the assembly, start under the ribbon cable to pry out.
    • All components should be removed with ESD safe tools.
    Vraag FixBot
    Voeg opmerking toe
  10. LG G2 Sprint Display Assembly Replacement: stap 10, afbeelding 1 van 1
    • Once all components have been removed the display assembly with be the only part left, the final step is to replace this part.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Ryan Bajnath
281 Reputatie
1 Handleiding geschreven
USF Tampa, Team 5-2, Lacy Fall 2016 Lid van USF Tampa, Team 5-2, Lacy Fall 2016
USFT-LACY-F16S5G2
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 1,734
