Ga door naar hoofdinhoud
LG Front Load Washing Machine Pump Hose Replacement
Wat je nodig hebt
    1. LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: stap 1, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: stap 1, afbeelding 2 van 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: stap 2, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: stap 2, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: stap 2, afbeelding 3 van 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: stap 3, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: stap 3, afbeelding 2 van 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Pump Hose Replacement: stap 4, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement: stap 4, afbeelding 2 van 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: stap 5, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: stap 5, afbeelding 2 van 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement: stap 6, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 6, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 6, afbeelding 3 van 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: stap 7, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: stap 7, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: stap 7, afbeelding 3 van 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: stap 8, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: stap 8, afbeelding 2 van 2
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the detergent dispenser: stap 9, afbeelding 1 van 1
      • Remove the screw(s) securing the detergent dispenser.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: stap 10, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: stap 10, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: stap 10, afbeelding 3 van 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: stap 11, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: stap 11, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: stap 11, afbeelding 3 van 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Open the door: stap 12, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Open the door: stap 12, afbeelding 2 van 2
      • Open the front door completely.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: stap 13, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: stap 13, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: stap 13, afbeelding 3 van 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Pump Hose Replacement: stap 14, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 14, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 14, afbeelding 3 van 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: stap 15, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: stap 15, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: stap 15, afbeelding 3 van 3
      • Use your fingers to pull the boot off its lip on the front panel.
      Vraag FixBot
      Voeg opmerking toe
    5. LG Front Load Washing Machine Pump Hose Replacement: stap 16, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 16, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 16, afbeelding 3 van 3
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
      Vraag FixBot
      Voeg opmerking toe
    6. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: stap 17, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: stap 17, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: stap 17, afbeelding 3 van 3
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
      Vraag FixBot
      Voeg opmerking toe
    7. LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: stap 18, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: stap 18, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: stap 18, afbeelding 3 van 3
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      Vraag FixBot
      Voeg opmerking toe
    8. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the filter trim: stap 19, afbeelding 1 van 1
      • Remove the screw(s) securing the filter trim.
      Vraag FixBot
      Voeg opmerking toe
    9. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: stap 20, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: stap 20, afbeelding 2 van 2
      • Pull the filter trim straight off the front panel to remove it.
      Vraag FixBot
      Voeg opmerking toe
    10. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the lower front panel: stap 21, afbeelding 1 van 1
      • Remove the screw(s) securing the lower front panel.
      Vraag FixBot
      Voeg opmerking toe
    11. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the door latch: stap 22, afbeelding 1 van 1
      • Remove the screw(s) securing the door latch.
      Vraag FixBot
      Voeg opmerking toe
    12. LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: stap 23, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: stap 23, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: stap 23, afbeelding 3 van 3
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Vraag FixBot
      Voeg opmerking toe
    13. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: stap 24, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: stap 24, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: stap 24, afbeelding 3 van 3
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
      Vraag FixBot
      Voeg opmerking toe
    14. LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: stap 25, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: stap 25, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: stap 25, afbeelding 3 van 3
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Vraag FixBot
      Voeg opmerking toe
    15. LG Front Load Washing Machine Pump Hose Replacement: stap 26, afbeelding 1 van 1
      • Remove the front panel.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: stap 27, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: stap 27, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: stap 27, afbeelding 3 van 3
      • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
      • Pull the hose straight off the assembly to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: stap 28, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: stap 28, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: stap 28, afbeelding 3 van 3
      • Remove the screw(s) securing the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: stap 29, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: stap 29, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: stap 29, afbeelding 3 van 3
      • Unclip the rear panel from the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Pump Hose Replacement: stap 30, afbeelding 1 van 1
      • Remove the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: stap 31, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: stap 31, afbeelding 2 van 2
      • Pull the hose straight off the air dome hose to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the air dome: stap 32, afbeelding 1 van 1
      • Remove the screw(s) securing the air dome.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Pump Hose Replacement: stap 33, afbeelding 1 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 33, afbeelding 2 van 3 LG Front Load Washing Machine Pump Hose Replacement: stap 33, afbeelding 3 van 3
      • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
      Vraag FixBot
      Voeg opmerking toe
    4. LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: stap 34, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: stap 34, afbeelding 2 van 2
      • Pull the air dome straight off its hose to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: stap 35, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: stap 35, afbeelding 2 van 2
      • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    2. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: stap 36, afbeelding 1 van 2 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: stap 36, afbeelding 2 van 2
      • Pull the pump hose straight off the drum to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    3. LG Front Load Washing Machine Pump Hose Replacement, Remove the pump hose: stap 37, afbeelding 1 van 1
      • Remove the pump hose.
      • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Bill Gilbert
40.207 Reputatie
261 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
69.555 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 107
Altijd: 2,616
